Bad Bird
Hi all,
I've had my big block Corvette less than a year, and it's been extremely reliable. I've never trusted the temperature gauge however, as it's almost always hovering around the first quarter mark. To cut a long story short, I went on a long cruise in ~90 degree weather (maybe 30 minutes at 60-70 mph, then an hour in stop-start traffic) and for the first time ever I saw the temperature gauge go up to about the 180°F mark on the gauge. This gave me cause for concern, as I had always just assumed that my gauge was off and that the first quarter mark was 180°F.
I had a non-contact IR thermometer in the shed, so I spent this morning attempting to re-create the 'overheat' condition. To start with, I went around the block to get some initial heat and see what the thermometer said. At this point, when I measured the heat on the upper rubber radiator hose I got something like 150°F, and the lower hose was very cold.
I then took the car out onto the open road for an hour (day off, and it's fun to just drive the 'Vette sometimes). To get the situation, I pulled the TH400 back into 2nd and drove along for a while and eventually got the temperature on the gauge to go to what it was during the 'overheat'. What I found when I measured the temperature at the radiator hoses was that the bottom hose seemed hotter than the top! (~188°F top, 197°F bottom). The car was idling at the time, btw. I got a maximum of 212°F at the top of the painted thermostat cover. It seems like the car really isn't overheating, but what would cause the lower rubber hose to be hotter than the top?!
