Ozzy
I have a 1980 I purchased a year or so ago. The previous owner was going to make it into a drag car. The current state of the car is a disaster to say the least. He started the car when I purchased it by hooking this wire to that wire to another wire, hold your tongue just right, pray to the gods of spark, and it fired right up.
Its now a year later and I don't remember his special combination of wires to start it.
at this point I just want to fire it up to be able to move it under its own power instead of pushing it every time it needs to be moved.
I do not want to try and use the existing wiring,I want to run a few wires and be done with it for now. Don't need charging circuit, just ignition and starter.
Does anyone have a simple schematic to achieve this?
Or do I need to take the time to look up the oem schematic and figure it out. Being as I am basically lazy I hope someone has the first option !
Thanks.
Thanks.
