What is the cranking RPM of a starter?
What is the cranking speed of of a starter motor? Anyone know the current draw while starting?
Current varies all over the map, with load...obviously a lo comp SB will draw less than 1/2 a hi comp BB, I hear it not higher than 200 amps anyway....
cranking speed is <500 rpm, once again that can depend on too many variables...primarily engine temp upon start.....as anyone in Minnesota will know....
:lol:
Current draw will vary with load, but can be as high as the full rated capacity of the battery. The starter is the only electrical part on a car designed to carry the full output of a battery.
The starter motor will also vary in speed, and may be stepped down if there is a gear reduction used to increase torque.
