rtj Well-known member Joined Nov 5, 2011 Messages 3,485 Reaction score 166 Sep 6, 2012 #61 I've got a dual cylinder Wilwood pedal assembly sitting in the garage. Has anyone seen these installed in a c3? It's a nice unit with a balance bar for proportioning. Last edited: Sep 6, 2012
BBShark Garage Monkey Staff member Joined Mar 5, 2008 Messages 5,208 Reaction score 267 Location Right here Sep 6, 2012 #62 rtj said: BBShark said: Something else to consider. The pedal lever ratio for power and manual are different Manual 1" master dia. 5.5:1 pedal ratio Power 1.125" master dia 3.5:1 pedal ratio Click to expand... Thanks. Is the factory pedal drilled for both? Click to expand... Yes. The pedals are drilled for both. The pushrod is in one hole and the brake light switch braket in the other.
