street strip 69 vette
468 4 bolt bbc, dart pro-1 310 runner heads, 9.97:1 compression, forged diamond ceramic coated pistons, forged eagle h beam rods, forged scat crank, arp head and main studs 229 236 @50 .640 lift 112 las cam factory 435hp tri-power with mechanical linkage, NOS tri-power nitrous plates, MSD digital 6 box, summit dual 12 inch fans, stewart stage 2 water pump, stewart 180* thermo, dewitts alum rad, areomotive A1000 pump, areomotive regulator, sumped stock tank. th400 built with jw ultra bell, PTC 3000 stall nitrous converter, 1350 joints front and rear on a custom drive shaft.
autofab 4 link, with nine inch rear, fab housing, S series center section, detroit locker, 35 spline axles, 3.25 gears, 325 wide BFG drag radial, willwood rear brakes.
yes this is a 2X4 behind the tire.
two years lots of hard work and too much money and the car went from this
to this
[ame=http://s237.photobucket.com/albums/ff28/brngrhd/vette/?action=view¤t=vette147.flv]
[/ame]
still lots to do and a bunch of tuning to but it runs drives and goes pretty good.
to this
[/ame]still lots to do and a bunch of tuning to but it runs drives and goes pretty good.
