Trailing arm rebuild - lots of photos
MYBAD79
Moderator
sunny Florida
Here's where it all starts:
Poly bushings are garbage, they crumble....
So after disassembly and some quality time with the sandblaster we can see how awesome the GM welders got splatter everywhere....
After welding up the arm and improve GM's welds and some time with a flapper sanding disc we are here:
Now the overlapping sheetmetal at the end of the arms get welded up:
21617e9d9d99cb2.jpg.
more parts blasted.....
21617e9d9daba9f.jpg.
All parts get three coats epoxy "Chassis Saver" then ready for re-assembly.... set up on the setup tool (old spindle that was polished down to allow slipping the bearings on and off):
Timken bearings:
With the flange nut torqued you want .001-.002" max endplay with oil only, no grease... .001" is perfect. Take patience to get there.
select shims to get it to .0015" endplay....
21617e9cdfc7bf1.jpg.
then continue assembly with new backing plate and parking brake shoes as well as SS PB hardware...
I thread the spindles 3/8X24 UNF and countersink the rotor holes - that way the rotors can be bolted to the spindle instead of riveted. Photos show the bolts/rotors after the spindle was already pressed in...
compression tool for front trailing arm bushings:
21617e9d9df20ef.jpg.
New front bushing installed, I only use rubber for obvious reasons....
finished ...
Good job. Nice southern parts.
I rebuilt three sets this year, on two sets I had to replace the spindles because they were slip fit, one set of spindles was good so I used them... slip fit is a controversal topic, on my own car I'd run them slip fitted but I sold two sets and wanted them to be to GM specs or better...
