saudivette
Clueless In Sandland
I was tidying up loose ends today, one of which was to connect the throttle cable to the carb.
Originally, the car still had the real long 82 Crossfire cable hooked up to the carb. I binned that and bought a standard cable but when I went to hook it to the carb today, using the brackets that were already mounted on the inlet manifold, it ends up at quite an angle
Any suggestions as to what I've done wrong?
Also, should the transmission cable be under tension as soon as the thottle is moved? As it's set up now, I think I could get away without needing a return spring on the throttle...
