clutchdust
Millionaire Playboy
kind of thinking about popping one of these under my car. two birds, one stone. thoughts? experiences?
http://www.dynomax.com/products/ultraflox.html
I read an article here recently about performance exhaust systems,and it showed some dyno runs between the H-pipe and the X-pipe, the X showed to produce more HP and TQ especially from the mid range and up. But the article also said that you should have either the X or H as close to the collector as possible to get the best scavenging effect, so i wonder how efficient this muffler would work for scavenging if it is placed at the back of the car???
It also talked about Dr Gas and found their design to be one of the best, but they are over a $100 for an X-pipe.
i don't think room would be a problem for me. i was thinking of mounting it where the original cat was. that thing was the size of a briefcase, so i have to think this would fit. of course that leaves me either just running straight pipe out the back, which would look a little goofy, or another set of mufflers. if i do that, i might as well just use an 'x' pipe and hang conventional mufflers in the back.
Does anyone offer a X-pipe for my Hooker sidepipes ??
Yes. It runs over the top just behind the upper edge of the windshield, and then has a balance tube that's just behind the drivers' head. Sort of looks like redvetteracer's with bigger tubes. You do need to remember they get a bit warm.:sweat:
:stirpot:
