Jsup
- Joined
 - Oct 31, 2008
- Messages
 - 810
OK, here's the build:
1990 Coupe
427 Pat Musi Small Block, naturally aspirated
Dart SHP 400 Block
Dart 215 Pro1 Plats
240/246 cam on 112
.602/602 lift using 1.6 RRs
42LB Bosch injectors pushing 50 PSI Fuel pressure using a high volume pump
Long tubes with 3 inch exhaust
OEM Ignition
700R4
3000 stall
3.07 rear
Question: On this fairly modest NA setup, any reason why I can't get the speed density tuned to work? Just wondering. I'm not saying it would be EASY, just wondering if it would work....
I am working with a well known, experienced tuner.
			1990 Coupe
Dart SHP 400 Block
Dart 215 Pro1 Plats
240/246 cam on 112
OEM Ignition
700R4
3000 stall
3.07 rear
