mrvette
Phantom of the Opera
Quote:
Originally Posted by 010752
I didn't want any you to run out and get this pump and especially make mounting brackets etc, just to find out it didn't pump enough.
I disconnected both the inlet and outlet hoses and fired up the engine. Keep in mind the Ford 4.9L (300 cu in) straight 6 is about as close as to a diesel as a gas engine gets, very torquey and low max rpm. I didn't bother to hook up a tach but my guesses should be close enough.
At idle 650rpm = approx 1" vacuum
At approx 1500 rpm = 10"
At approx 2500 rpm = 15"
At at max which should be no more than 3200 rpm = 20"
With the outlet port open it was also pretty noisey and restricting the outlet with my hand obviously reduced the vacuum too. I didn't measure the intake hose, but I'll guess at that too at 1" dia and I would suggest that at least that size is used when trying it.
So I would guess that if you are inclined to go this route, then the pump should be suitable.
my reply......
Well, a few hours ago I found a FORD smog pump on a forgotten shelf in my garage...must be some tear off up north yet and so I pulled it down to look, and inspection....it works fine....fired it up with my electric drill on high speed, and I dunno the Revs on it, but the above is certainly good information....Is that CRANK/ENGINE rpm's or what kind?? if so, what is the approx pulley ratio size?? I have a rather large L98 pulley which naturally fits that Ford pump just fine....same pattern....I was pulling up to 15 psi vac with the drill on full speed....did an easy 5".... just hooked up a bunch of hoses and clamps....used my mani vac gauge...
now to fit it into my L98/bastardised LT1 FI mani/accesory drives....
NOW comes the M/E part....fit that bastard in there without going NUTZZZZ....
stay tuned folks...
:skeptic:
my reply......
stay tuned folks...
