mrvette
Phantom of the Opera
Water is heavier than fuel. What I do is remove the fuel line at the fuel rail and hot-wire the fuel pump. Fill a glass with fuel. If there is any water, it will settle to the bottom of the glass. If none is present in the glass, there is none in the tank.
That is what I would think also...BUT.....there is that sock on the pickup, and I wonder if it passes water as easy as fuel.....I would think SO, but in the dim past I have found proven water in this damn tank....
the tank will very occationally take to having pressure in it, if I fill up the tank that float valve to keep gas outta the EEC line is sealing the line....so IF I drive the car a lot, like on a road trip....then when stopping for gas...the tank has pressure in it when popping the filler cap....so I know there is no way for water to be getting IN the tank from rain....but I swear, there is something fucked up with the gasolines here......closest Chevron station is about ten miles ONE WAY from me.....damnit....
wonder if I can just go to Walmart and buy a whole case of that techron just to keep it around, and consider it another expense, like toilet paper....
bury the fucking problem THAT way.....seems stupid though....
:shocking::gurney:
