keywestjack
- Joined
- Apr 24, 2008
- Messages
- 258
- Reaction score
- 0
Can I use 3/8 fuel hose from the manifold to the booster? If not any suggestions? Thank you, Jack, Happy Easter!
If it fits, sure. It is just vacuum so shouldn't be a problem. May be some better choices out there, but I would probably use fuel line too. Of course, the really trick thing to do would be to bend steel line and just use rubber between the engine and firewall.
lots of g-body cars had that a line just like that
fuel hose is fine for vacuum, however, vacuum hose is not fine for fuel (despite what the Bubba that used it on my v-8 blazer thought)
:thumbs: FIRE!If it fits, sure. It is just vacuum so shouldn't be a problem. May be some better choices out there, but I would probably use fuel line too. Of course, the really trick thing to do would be to bend steel line and just use rubber between the engine and firewall.
