noisy rear end - 2006 C6
MYBAD79
Moderator
sunny Florida
Noise when tuning counterclockwise (left) .... there's a clunking noise from the right rear when turning/circling left(counterclockwise), right rear suspension loaded and seems to be making noise.... .... neighbor just bought this 2006 C6 today, IMO it should go back for a full refund as something is fishy with the rear end.... any other ideas ??
There's been a couple of service bulletins regarding rear end noise
Rear Axle Chatter Shudder on Turns - keywords differential fluid noise oil #PIP3559 - (Sep 22, 2005)
1999-2006 Chevrolet Corvette
2004-2006 Cadillac XLR
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Rear axle chatter or shudder on turns on Chevrolet Corvette and Cadillac XLR.
Recommendation/Instructions:
If this is the first complaint for this condition flush and fill the rear axle with P/N 89021669 (in Canada 89021670) gear lube and 4 ounces of the friction modifier additive P/N 01052358 (in Canada 992694).
If this is a repeat complaint or the condition persists after the flush and fill, replace the right and left rear axle clutch packs following published service procedures.
After clutch pack replacement use 1.6 l (1.69 qt) synthetic axle lubricant GM P/N 12378261 (Canadian P/N 10953455). and 4 ounces of the friction modifier additive P/N 01052358 (in Canada 992694).
Note: 2006 Z06 equipped vehicles require 2.55 l (2.70 qt) synthetic axle lubricant GM P/N 12378261 (Canadian P/N 10953455) and approximately 190 ml (6.4 oz) limited-slip differential lubricant additive GM P/N 1052358 (Canadian P/N 992694).
Note: Export vehicles use 2.01 l (2.12 qt) synthetic axle lubricant GM P/N 12378261 (Canadian P/N 10953455) and approximately 150 ml (5.1 oz) limited-slip differential lubricant additive GM P/N 1052358 (Canadian P/N 992694)
The latest one
Date: 01-09-2008
TSB: #07-04-20-002A
Document ID# 2048181
2005 - 2008 Chevrolet Corvette
Subject: Rear Axle Clunk and/or Chatter Type Noise on Turns
(Drain/Refill Rear Differential Fluid) #07-04-20-002A - (01/09/2008)
Models: 2004-2008 Cadillac XLR (Including V-Series and Export)
2005-2008 Chevrolet Corvette (Including Z06 and Export)
This bulletin is being revised to change the fluid recommendation and to remove the requirement of adding friction modifier. Please discard Corporate Bulletin Number 07-04-20-002 (Section 04 -- Driveline/Axle).
Condition:
Some customers may comment on a clunk and/or chatter type noise from the rear of the vehicle while making turns.
Cause:
This condition may be caused by slip/stick of the posi-traction clutch plates due to insufficient limited-slip axle additive. As plates slip and stick, a jumping or jerking feel occurs accompanied by a clunk noise.
Correction:
Important: DO NOT remove the differential cover from the rear or the two sides. It is not necessary to flush the old fluid from the differential.
Drain and refill the rear differential fluid using the procedure listed below.
Draining Procedure:
Raise and support the vehicle. Clean any dirt from around the differential drain plug. If not equipped with a differential cooler, remove the drain plug (1) and washer (2) from the differential.
If equipped with a differential cooler: 4.1. Using a bent tip screwdriver, remove the quick connect fitting retaining ring (3) from the quick connect fitting (4) and discard the retaining ring.
4.2. Remove the differential cooler inlet pipe from the differential nut.
Drain the fluid.
Filling Procedure:
If not equipped with a differential cooler, install the drain plug (1) and washer (2) to the differential. Tighten the differential drain plug to 35 N•m (26 lb ft).
If equipped with a differential cooler: 2.1. Install a new retaining ring.
2.2. Connect the differential cooler pump inlet pipe (2) to the differential. A distinct snap should be heard or felt when assembling the cooler pipe to the fitting.
2.3. To ensure the cooler line is properly installed, give the cooler pipe a gentle pull.
Clean any dirt from around the differential fill plug. Remove the fill plug and washer from the differential.
Important: DO NOT add any limited-slip additive (friction modifier). With this new fluid (Dexron LS Gear Oil 75W-90) it is no longer required to add friction modifier. If friction modifier is added, it will cause the fluid to lose some of it's friction reducing properties as well as reducing seal life.
Fill the differential with the new DEXRON® LS gear oil, P/N 88862624 (Canadian P/N 88862625). Refer to the table listed below for lubrication specifications.
Check the fluid level to ensure it is even with the bottom of the fill plug hole to no lower than 6 mm (0.25 in) below the opening. Install the fill plug and washer to the differential. Tighten the differential fill plug to 35 N•m (26 lb ft).
Important: Steps 8-13 are for vehicles equipped with the differential cooling system. For vehicles not equipped with the cooling system, proceed to step 14.
Raise the vehicle so the wheels are about a foot off the floor. Make sure the wheels can spin freely without obstruction from the hoist or any nearby items. Start the vehicle and put the transmission in second gear. Slowly accelerate to 10 mph and hold this speed for one minute. Turn the vehicle off. Raise the vehicle. Check the fluid level in the differential. Add fluid until the recommended level is reached. Lower the vehicle.
Once the differential fluid has been changed, the vehicle must be driven in 8-10 tight figure eight maneuvers to heat the fluid and allow the fluid to be worked into the clutch plates.
Lubrication Specifications Application
2004-2005 XLR (Including Export) and 2005 Corvette (Non Export)
1.72 liters
1.85 quarts
2006-2008 XLR (Including V-Series and Export) and 2006-2008 Corvette (Non Z06)(Non Export)
2.0 liters
2.11 quarts
2005 Corvette Export
1.88 liters
1.99 quarts
2006-2008 Corvette Export (Non Z06)
2.16 liters
2.28 quarts
2006-2008 Corvette Z06
2.75 liters
2.91 quarts
Parts Information:
Description: DEXRON® LS Gear Oil
Part Numbers:
88862624 (US-1 Quart)
88862625 (Canada-1 Liter)
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation: F9709*
Description: Drain & Refill Rear Axle Fluid
Labor Time: 0.6 hr
* This is a unique labor operation number for bulletin use only. It will not be published in the Labor Time Guide.
© Copyright General Motors Corporation. All Rights Reserved.
2005 Chevrolet Corvette
On a side note, check the diff for leaks, my father's C6 develloped a slight but steady leak which was fixed under warranty.
Thanks. I told her today that I was going to change the fluid and/or add the additive for her and had a closer look at the car. Passenger side door and rocker have been repainted. Looks like someone spun the car and hit a curb or a pole.... f'ed up the door and rocker.... told her to take it back...... don't know the laws about selling used cars but she bought from a dealer ... hope she gets her money back....
She says the dealer told her that there were scratches on the door and that's why they painted the door - I don't believe that story, I told her I don't believe it, the rocker was painted too, what she does from here is her business.....
