MSD 85551 Distributor
Jsup
Anyone have a problem with an 85551 distributor, I'm not getting an output to my ECU. Before I deem it defective I have some questinos. .
I took the dist apart to lock down the timing advance, put everything back together.
Anything you think I need to look at, I changed over the ignition and ECU in one shot, I am not getting a signal from the distributor to the ECU, I checked pin outs and continuity to the ECU. All seems OK. I can't seem to find a problem
Is it common these distributors have out of box failures?
__________________
