length of trailing arm pivot to spindle center?
daveL82
I'm in the process of aligning my rear A arms and need to use the pivot location to spindle center as a baseline. Wheel base should be 98 inches but if front wheel is turned slightly this can be off.
I'm not following? are you looking for wheelbase information?
I'm needing the distance from trailing arm pivot (front bolt hole in frame for bushing) to center of spindle
The center of the spindle to the center of the trailing arm pivot is 17 3/8
