chris75stingray
Active member
- Joined
- Aug 29, 2008
- Messages
- 35
- Reaction score
- 0
these are used assemblies that came off of my 75. this is everything i took out when i switched to the lemans fixed headlights. included is the actuator support frame, actuators(these were new about 5 years ago but the outer boots are ripped so they did not open with vacuum but did close with vacuum. i'm guessing that one of the rebuild kits from one of the vendors should fix the problem.), bezels(fiberglass), both actuator relays, headlight housings, all the bolts, springs,pins needed to reassemble,and the vacuum hoses from the front of the car.
***not included are the bulbs,bulb cups,headlight adjusters, or warning switches. but they can be bought from vendors.
i'll take $400 / obo for everything plus actual shipping costs
Thanks, Chris
Thanks, Chris
