69427
- Joined
- Mar 30, 2008
- Messages
- 3,077
- Reaction score
- 38
Yeah, I spent some time bending stuff to see where I'm at presently. I was having serious issues with the anchor point (my carlift runner) bending, throwing off my "datum" point, as it were. I made some changes, along with adding some additional material on the runner to distribute the force over a larger area of the runner surface. Seemed to help.
I then placed my dial indicator at the frame area near the batwing mounts (which I'm using as the frame anchor attachments). I was getting some bending of the mounts during the torsion inputs. I suspect my mounts might be a bit more susceptible to bending versus the factory batwing mounts due to my having to narrow the batwing width to clear the C4 bearing carrier assembly, which then required somewhat longer and more angled mounts. I welded in some additional gussets in the mounts, which then reduced the frame movement in that area to about four thousandths of an inch. Small enough for now, and ignoring this error will give conservative readings on the measurements going forward .
I put my dial indicator under the rear (pinion) crossmember and then applied the 2000 ft-lbs of torque up front. I got 150 thousandths downward movement on the frame. At 26.5 inches from the frame centerline I got a calculated angle of .32 degrees, yielding a rate of 6250 ft-lbs per degree. Given how flimsy the rear kickup area appeared when I first got the frame, I can live with this number.
I next measured the delta movement of the area between the pinion crossmember and the trans crossmember. I calculated this angle at .24 degrees, giving me a torsion reading of 8333 ft-lbs per degree. I then removed the torsion tube I have mounted between the trans and pinion crossmembers. After applying the load again, I ended up measuring and calculating a reading of 6978 ft-lbs per degree, a reduction of 1355 ft-lbs per degree (or about 16%). I checked my calculations for the torsion tube (using the formula in my "How To Make Your Car Handle" book), and got a theoretical torsion rate for the tube at 1316 lbs per degree. I had to do several conversions to convert pounds per inch into pounds per degree, so I hope I did it right. But regardless, I'm still reasonably happy with this section of the frame.
The front section of the frame, from the trans crossmember to the suspension crossmember, is the most difficult portion to stiffen up. This segment length is roughly twice the length of the center and kickup sections, with the engine and transmission getting in the way of installing efficient stiffening structures. I measured a deflection (relative to the trans crossmember) of 370 thousandths. This calculated out to .8 degrees, and a result of 2500 ft-lbs per degree. For the same unit stiffness I would expect this section to be flimsier due to its longer length, but I'm still not happy about it. I dropped the engine and transmission back onto the frame a couple days ago to study where there's available real estate in the front half of the wheelbase to possibly add more crossmember/struts/gussets to stiffen this up some more. Given that these frames are essentially three torsion sections end to end, the calculations give me an overall reading of just under 1500 ft-lbs per degree. Stiffening up any of the three sections will yield a higher overall number, but given these first run numbers, improvements to the (long) front section should yield higher percentages of improvement to the overall number. The problem is that this section is the toughest to improve, given the space restrictions.
An interesting, but frustrating aspect of this has been the difficulty of trying to determine weak "nodes" in the frame. I put a couple laser levels on different portions of the frame and aimed them towards other areas of the frame to try to visually see the twist of one portion of the frame versus another. In most, if not all, instances, I could see the overall frame move or twist a bit as I applied the torque, but the lasers would continue to point to the same point on the frame. I've essentially got no usable information from trying this particular test.
Still got a couple things I want to do to the front of the frame, along with some possible measurement techniques to try to streamline the readings, and hopefully reducing any errors in these measurements.
More to follow during the week.
