MYBAD79
Moderator
OK, I rebuilt the calipers with O-ring pistons and installed new rotors (drilled/slotted) on the front - while I did not expect the rotors to make a big difference the semi metallic pads seems to be a good step up from the organic $15 AutoZone pads that I used with the stock rotors.
I installed brake hoses with 5/8" hex at the connection to the caliper (stock size) - the SS braided hoses that I had for almost 5 years have a 9/16" hexagon that tears the copper washer if tightened too hard....
I checked rotor runout and it's below .004", I use DOT5 silicone fluid, I have no leaks and I got O-ring pistons :nuts:... the rear brakes are still stock.... I am testing this step by step :nuts::clobbered:
First impression after 30 miles: brakes feel definitely better than they ever have. The brakes are by far not as good as the brakes on the C6 but a lot better than they were with stock rotors, cheap organic pads and lip seal calipers.
I accelerated a few times up to 70-75, then applied the brakes to slow down to 30-40.... did that a few times just to see how the brakes "feel".... so far so good.....
The pads seem to work really good once they got a little temperature.
When I got home I noticed the paint on the calipers and rotor hats smell really bad, amazing how much temperature gets into these calipers.... never noticed that with the old setup, maybe the organic pads create less heat ????
Can't wait to get the rear done and the system bled with the pressure bleeder.....
