Belgian1979vette
What would be a good fan for over 7000 rpm usage ?
Run an electric fan and forget all about it.
Gotta agree here. A mechanical fan at that speed would be dangerous, not to mention worthless. Above 30 MPH or so, the fan does squat.
i'm gonna offer a differing opinion here. If you're talking about a normal passenger car with a large frontal cross section i would agree. The C3 needs some assistance from the fan at medium and highway speeds. That's why they put that big honking fan clutch in. It provides more torque throughout the RPM range.
No need for an alu rad, just us it on your existing one. A spal fan is around 200 Euros, even less at some shops. Very easy to mount by using the pins you stick through the rad (optional) or with some simple brackets welded to the upper and lower support channles (they're steel)
Super clean looking, easily thermostatically controlled from the cyl. head, relay switched, running off the alternator lug with an inline fuse.
oops. didn't mean to yell.
Attack of the caps lock.:lol::lol:
