Differential Fluid Change instructions '88 Vette
[email protected]
New member
Looks like I will either need to suck out the fluid with(?) or install a drain hole (how to do instructions). What type of lubrication and additive to use. Thks! Jim
There isn't a drain plug so you will have to pump it out. I did this with a pump that was used to pump oil into the lower unit of a boat. Just put a flexible tube onto the pump and stuck it in through the fill plug.
Used the same deal to fill it. Worked great and I think it was less than $10.00
