Connectors
Now it is. messed up the " " and the URL.
Regarding the find. They provide almost all connectors used in the C3. So if one is missing or flimsy you can re-terminate and put a new connector to the harness. Also they provide the terminators. With those you can "mod" your firewall connector to integrate thicker gauge wire in to the harness. For example for HEI ignition conversion.
Except for the front lighting 1/2 of that bulkhead connector, years ago I rewired the entire car, eliminating the other 1/2 of the thing completely, rerouting through a hole up top and simplified the entire harness, pulled out enough usless wire lengths to make a entire DPFI harness.....:gurney::evil::shocking:
