00fxd
I have cut and modified my cross member making it removable. The holes are all sleeved. The frame became a bit less rigid than I expected when the crossmember is not installed. I did have to push the frame rails apart to re-install, I expect that it will be more stable when the body is on. I drilled the holes and installed the plates before I made the cuts so everything is back right where it came from.
