build a smart (shark) bar...
MYBAD79
Moderator
sunny Florida
The harness bar that is available for $500 or so is really nice but maybe a little too pricey for some... incl. me.....
here's how you can easily build your own:
Behind the plastic sail-panels you'll find the threaded hole for the seatbelt and a oval hole that you can use to attach a plate....
I cut these pieces from 3/16th plate:
and bent it slightly to conform to the B-pillar
here's the two pieces bolted onto the birdcage or B-pillar:
tack welded, removed and welded....
after welding:
painted;
I used a 1 1/2 " pipe from the hardware store and welded a nut into each end
the next pic shows the bolt that screws into the nut that is welded into the pipe
finished: the $50 sharkbar....
:smash::smash::smash::smash:
