Bell Housing cover bolts
keywestjack
Does anyone know where I can get the bolts (approx 1/2 inch in length) for the bell housing cover on a 1990 (automatic). They are not the same thread pitch as a regular 6mm bolt. Thanks, Jack
A 1990 is still "SAE metric". As a general rule, most SAE fasteners sizes are 6mm x 1mm, 8mm x 1.25mm, 10mm x 1.5mm, etc.
Unfortunately this "general rule" doesn't always work :banghead:
The bellhousing bolts on my '89 truck roller block are 3/8-16 9/16 cap just like olde tyme chebbies....
:thumbs:
I recall someone saying the V8 hardward didn't go metric on the drill/tap until the LS came out....makes sense, I guess....
:eek::surrender:
Like Gene says, they are regular 3/8-16 like most outside fasteners on the SBC, same for LT1/4. LS was indeed the 1st for metric all over.
No way a bellhousing cover is using anything approaching 3/8-16.
Automatic transmissions were the first components to go fully metric.
my 1pc rms block is a 87 or newer and the bellhousing bolts are not metric, think they're 3/8".... anyways.... If I read this correctly the question is about the bellhousing cover (dust shield ??) bolts ????
Metric 6mm (M6) is way smaller then 3.8" so I assume the question is about the dust shield bolts....
I believe (and might be wrong) that the dust shield bolts or threads are 1/4", not metric....
Oh bell housing cover, I figured bellhousing to block.
Those small bolts? Hell if I know what they are LOL
Sorry about the confusion. :o You are right, I did mean dust shield. On another look the tpi don't look like anything I have seen before. BTW, thanks guys for your time. Jack
The TPI is metric...I don't know the sizes....I never bother with the dust shields, leave it off for better cooling....
:bump:
:bump:
Thanks Gene, I think I found them:
http://cgi.ebay.com/ebaymotors/ws/e...4ff986c19&rvr_id=&ua=WXI7&itemid=400095181526
