Auto tran cooling line pressures.....
mrvette
Phantom of the Opera
NE Florida
Some guy saying that auto trans cooling line pressure can well exceed 100 psi, I say bullshit, what say you all????
figger MAX pressures.....
issue at hand is a friend's V10 '96 Dodge Laramie 2500 pickup....
the lines go through the rad, then the largest trans cooler I ever seen on a 'normal' vehicle.....
I figger almost NO pressure....20 lbs, if the fluid is moving....
:amazed:
A 700 will jump the cooler line pressure way up in 4th gear to drive more fluid thru the cooler. Even pulling full TV will make it go up. It's pretty much line pressure in other gears.
