69427
- Joined
- Mar 30, 2008
- Messages
- 3,077
- Reaction score
- 38
My dad had several antique JD tractors (30s and 40s vintage) which he enjoyed as a retirement hobby. The older JD engines didn't have thermostats, but they had a shutter system in front of the radiator so the driver could regulate the airflow into the radiator to set the coolant temps. That got me thinking about a few engine and aero issues relating to our antique C3s when we try to have some high speed fun with them. It seems counterproductive to let great volumes of air into the pre-radiator plenum area, creating lift, and also producing such a great heat exchange out of the radiator that the thermostat ends up restricting the coolant flow to maintain a minimum coolant temp. It seems to me that it would be better to restrict the airflow into the plenum (with the positive side-effect being reduced lift), and causing the thermostat to open wider, allowing higher coolant flow. Higher coolant flow, while still maintaining the same BTU heat exchange with the air, would reduce the temperature drop across the radiator, and as we know, this would also reduce the temperature rise across the engine. Higher coolant flow will scrub away steam bubbles better, and reducing the cross-engine temperature delta should help engine longevity.
My point is, I think I'm going to add another item to my modification list for the '69. I'm thinking about fabricating some blockoff panels to attach to the three underbumper grills to restrict the flow into the plenum (I still have the undergrill openings and a pace car spoiler to obtain air). If I overreach with this, or end up running on a particulary hot track day, I can always remove one of the blockoffs. So far I've had little overheating issues with the stock radiator during track days, and last year I put in a new DeWitts aluminum radiator. The new radiator doesn't have 40 years of internal scaling in it, so it ought to be a more efficient heat exchanger than the "well deserved retirement" original.
Just something I'm kicking around. Any thoughts or comments?
thanks,
Mike
thanks,
Mike
