Imo Apita
- Joined
- Feb 28, 2009
- Messages
- 244
Planning on aluminum heads on my (hopefully) soon to build 383.
Found a post on CF that has me scratching my head.
Never heard of this being an issue.
The fact that I've never heard of it doesn't mean that much so is there any merit in the above statement?
I know of the different expansion and contraction rates but is it really something to be concerned about?
Just ignore and go with the head gasket the head guy recommends?
Curious minds would like to know.
The surface needs to allow the aluminum head to move/slide around as it expands and contracts faster than the steel block. Both pieces are moving at different rate as they heat up (and down). Zero deck or +0.025 stock deck has nothing to do with this. It's the finish on the deck and head that will allow the aluminum head to move rather than tear the gasket (or what ever happens at the micro level). Again, the block and aluminum head should have an Ra of 20-50 while an iron head to iron block should be 60-120 Ra. At least thats what the professional machinists write and i just looked it up again but i'm not even a machinist so take it for what its worth
