Hey guys,
I have been pouring over the dyno mania article on the 2007 engine masters challenge and I have come up with the following tale of 2 327s.
1 is a ported stock casting head with a mild solid cam, and the other is an AFR headed 327 with a larger solid cam. I dont really care about the variation in camshafts because different heads should have different cams. Different heads have different strengths and weaknesses. In any case lets continue.
As we can see the ported stock head combo was dramatically superior to the AFR head under 5000 rpm and at a noticable disadvantage above 5000rpm.
I will let you draw your own conclusions. Mine are as follows:
The AFR headed 327 is a really good high RPM combo and would tear it up if it was never forced to compete below 5000rpm. Probably given our M21s close ratio probably wouldnt spend to much time below 5000 rpm anyway down a 1/4 mile track. If I were a drag racer it would be my engine of choice. The other 327 would probably be a better street engine, and maybe better in other forms of racing like road racing or autocrossing. The ported stockers also scored better on the 2007 Jegs engine masters challenge.
So the major lesson to take away - the best combo is the one that meets your intended purpose. Before you pick up a catalog and buy the most expensive shiniest part with all the right brand names, and be lauded by the interweb fanbois ask yourself is it right for your intended application? Who knows maybe some ported stockers IS right for what you are doing.
An AFR 195 CNC ported head was in the top 5 on a 302, and made a ridiculous amount of power and torque. The winners used some raised runner racer pro heads from australia.
Well matched components are well matched components no matter what. But well matched to what?
