700R4 Help
theafus
Active member
I am trying to put a JET 61650 lock up module in my 84 corvette and it says to unplug the factory harness near the tailshaft on the passenger side which is supposed to be a 4 pin conector, I cannot find any wires going to the passenger side of the tranny after the starter but I did find a 2 pin plug on the drivers side is that the one for the torque converter if so will this module work that I have or do I need a differnet one
That should be it, if it's your stock transmission that is the right location. Want to be 100% sure, drop the drain pan and look. If that's the TCC control, the wiring inside the pan should run from there to a point about an inch from where your trans filter goes into your case. That is definetly the TCC.
The 4 pin is the TCC connector- in the picture, it's just in front of the round black cover (governor) It's beige and is installed vertical. The 2 pin connector on the tailshaft housing is the speedo..
