6 pt. rear bars thru window or inside car?
73c34me
Laingsburg, MI
As I am getting closer to the 6 pt. cage intall- I would like feedback on this.
73 coupe, the rear bars from the hoop- bent to clear the rear window frame on the way to the frame-OR- replace the glass window with plexiglass & run the hoops thru the window then thru the rear deck to the frame.
Similiar to how pick up truck bars pass thru the rear window. thnx
How much bend?
I'd vote to keep it in the car if you can without a lot of compromise. Can you reinforce the bend to the floor with small diameter runners?
Pics or sketches of the proposal?
Keep it in the car, Without the window trim you can get them pretty far back
