rabiddawg
This is for all us lonely gear heads that don't have a car buddy close enough to help out.
I recently had to remove the tranny from my 81 and as you know, taking something out is often easier that getting it back in. After trying two different evenings and two different angles of attack I had decided to remove the engine and reinstall the both of them together. At the last minute I decided to ask my neighbor if I could borrow his motorcycle jack and boy was I glad I did.
The mc jack has two flat plates with rubber cushion that support the bike. This serves as a perfect platform for the tranny pan. I place the scissor jack that came with the car and a 2x6 under the front crossmember and jacked it (front of car) up high enough to slide the tranny under the car. Then I placed a 2x4 6" long on edge under the edge of the pan. This allowed me to roll the tranny over far enough to get the mc jack partially under the tranny. You will have to muscle it the rest of the way. After that the rest is easy because the mc jack holds the trans stable and you can shim under the pan to get the angle you need.
I started with the car on the ground at 8:30 am Sunday and by 10:30 I had four bolts in the tranny and made it to 11:00 mass. I buttoned up the rest after lunch.
I guess this is kinda long just to say that everyone needs a motorcycle jack.
