Aftermarket Door Lock Actuators
Is it normal for an aftermarket door lock/unlock actuators to disable the key lock? If I try to turn either door key cylinder, they won't turn at all.
Do you have the polarity of the motor wired correctly???
I have a ebay set on my truck, all 4 door sets....and it works normally....it's a small motor on a rack with a steel 'wire' that clamps to the inside door lock rod....IF I use the key on the driver's door it unlocks all the rest of the doors too....
or lock it, with key or if I flip the lever up/down....check your adjustments....or motor polarity....
:waxer:
With the key FOB, the doors lock and unlock normally. That leads me to beleve the motor is wired correctly. The problem is the key, it won't turn in the cylinder.:confused2:
