70 Vette differential
tpvets
New member
I have a 70 vette differential and the right shaft has no snap ring groove. have anyone ever herd of this???
If it's worn that far the dust shield will also cut into the housing
TT is right on with this, if you have axles without a groove then approx .200" has worn away and you most likely need an overhaul. There should be a /18" lip at the seal, if it's gone it already has hit the diff.
Now if you have aftermarket axles, they "should" have the groove and I haven't seen one without it but if there is no axle endplay who knows.
Most likely you have worn axles- although original 63-72's are pretty good and many I reuse. 70 diff's are kind of rare in respect to the numbers because of the strike that year. They were the only ones with the 3 letter prefix stamped.
