Go Back   VetteMOD.com > VetteMOD Technical Discussion > EFI
Reply
Thread Tools
  #1
Old 06-02-2008, 03:28 AM
Dirtbuster1's Avatar
Dirtbuster1 Dirtbuster1 is offline
United States | Addict
My Photos: (46)
Default IAC Motor Test
Is there a way to test my IAC motors. I have driven about 20 miles now & they still have not reset. Is there a way to ohm them out. If I took them out when starting should they respond.
The car is still not idling up when cold. If you try and drive it cold, it is very sluggish & tries to stall.I don't want to buy new motors at 70.00 a piece & find out there is another problem.
  #2
Old 06-02-2008, 01:16 PM
mrvette's Avatar
mrvette mrvette is offline
My Photos: (3)
Default
They have 4 pins?? if so, two have some continuity, the other two will have damn close, and there is NO conduction betewen the pairs....
the IACs I have on my L98 t body are similar, I suspect....screw in jobs abut 1.5 inches diameter and like a 1/2 NPT thread size....unscrew the things are clean them with carb cleaner, then blow them out, and a small dep of silicone spray....spray out the tbody IAC passages.....clean the tbody around the airvalve....black gunk buildup.....
put it all together and do the IAC set proceedure.....
hope that helps...
__________________
I love how Progressives want to have Darwinism taught in schools but denied as a reality in life.
All products should say "Do not use if your stupid."
  #3
Old 06-02-2008, 05:17 PM
Twin_Turbo's Avatar
Netherlands | Der Maulwurf
My Photos: (1233)
Default
they are STEPPER motors!!!!!!!!!!!!! You can NOT just test them like that.
__________________
  #4
Old 06-02-2008, 05:50 PM
Bullshark's Avatar
Bullshark Bullshark is offline
My Photos: (99)
Default
MegaSquirt has a very informative page on IAC's Take a look at it, it may answer all your questions. If not, fire away.
Bullshark
  #5
Old 06-02-2008, 08:19 PM
My Photos: (46)
Default
Update,
I took the motors out today and checked them out. Both ohm 57 ohms on both sides of the motors. Put ECM in diagnostic mode, and they both move in & out about 1/8" inch. I reset them to 15/16" and reinstalled. changed ECM again for the hell of it, & the front IAC didn't move. The Rear IAC moved all the way in and stopped. The motor wasn't running even. Took them back out and remeasured gap. Same result.
If I screw them in & out by hand, one of them works ok, the other shaft does not want to go in unless I put alot of pressure on it. I unscrewed the shafts again, & put on some loctite. Don't know if this will help, but what the hell. Called O'Reillys and I have 2 coming tommorow if I need them. 70 bucks a peice.
Any suggestions
  #6
Old 06-02-2008, 09:04 PM
mrvette's Avatar
My Photos: (3)
Default
Quote:
I"m checking just continuity.....I know they are steppers...
just covering a base....I have never had one fail completely and cleaning has allways fixed the sluggish behavior....tbody need be clean in and out, the passages, and the blades...holes....carb cleaner and a air jet does it right in place....I suspect same for the cross fire....
  #7
Old 06-02-2008, 09:15 PM
Twin_Turbo's Avatar
My Photos: (1233)
Default
I've never had one fail either, well..they do fail if people try to move the pintle themselves. It's just a std. GM delco stepper motor.
  #8
Old 06-02-2008, 09:22 PM
mrvette's Avatar
My Photos: (3)
Default
STANDARD?? no such thing from what I seen...they have some 3 differant pintle heads.....and of course differant passages, and then we get down to these things are no longer screw in but some plastic bolt on
getting to like bending sheetmetal anymore....
Mass production my ass.....
a box is a box is a box allready....fine one that works well, produce IT, and fix the problems with the existing BOX, not reinvent the wheel....
ah nevermind, I in a pissy mood, fucking idiots of the world.....
lousey day at work with much adoo over nothing....
  #9
Old 06-02-2008, 09:28 PM
My Photos: (46)
Default
TT,
Could you explain to me about moving or damaging the pintle. Is it normal to be able to unscrew the shaft. I am assuming since there are 2 coils that flux moves the shaft in & out.
Any suggestions would be great.
  #10
Old 06-02-2008, 09:33 PM
Twin_Turbo's Avatar
My Photos: (1233)
Default
If you forcefully push it in or pull it out it will damage the IAC
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
