clutchdust
Millionaire Playboy
Rebuilding the engine in this Suburban I just picked up and I noticed the cam bearings pretty much look like shit. I really wanted to have it running this weekend so I thought "how hard can it be to replace cam bearings?" Well, I found out. For one, I don't have the cam bearing installation tool so I was "rednecking" it. So you don't make the same mistake, a seal driver is not the same as a bearing driver. Damn it.
So after some cussing and throwing and one set of cam bearings, I came up with a plan. I picked up another set of cam bearings and gave it a try. All seemed to go reasonably well. I got all five bearings in with what appeared to be minimal fuss, and yes, I did pay attention to the numbers and where they went. But when I went to actually install the cam, I could barely get it through the #2 bearing and when it went, it had shaved off a fine layer of the bearing surface. At that point, I knew I had pissed away another set of bearings but I figured I would at least run it all the way down and see how she sat. Cam went through #3 with no drama but I got to #4 and it told me in no uncertain terms to pack sand.
I don't know what the deal was but #2 and #4 just weren't worth a shit. If I remember right, those two are the same size bearings so I just don't know what's going on there. Either way, my buddy just bought the installation tool so I'll give it another stab with the right equipment and see if that solves my problem.
In the meantime, any suggestions from those of you who've actually done this?
