Go Back   VetteMOD.com > VetteMOD Technical Discussion > Chassis, Steering and Suspension
Reply
Thread Tools
  #131
Old 01-28-2011, 09:50 PM
macx macx is offline
United States | Member
My Photos: (0)
Default
Thanks!
I'd seen that before early in my research so didn't understand all that was happening. Now it all pretty much falls into place and makes more sense.
Looks like way way too much work for what I want to achieve, but obviously
a great project.
As I'm not concerned with squat and dive - not only won't be driving it to that extreme but probly won't have enuf sheer power to make it happen in any significant way out of mild engine upgrade - I think I'll do the 6 link on the stock C3 suspension. I can make that up myself reasonably easily and at low
cost and I believe it will do the majority of what I'm looking for.
BTW thanks for that tip on posting emails - I never did know that. I've got
very vigorous security apps and blockers but still do get some spam altho haven't had any real incursions in the several years since I educated myself on that and installed the apps. Every little bit helps!
  #132
Old 01-28-2011, 10:21 PM
denpo's Avatar
denpo denpo is offline
Canada | Carburated Nihilist
My Photos: (496)
Default
You can still edit your post, maybe it's not too late.
__________________
“In theory, theory and practice are the same. In practice, they are not.”
-Albert Einstein
  #133
Old 02-25-2011, 05:23 PM
Stingxray's Avatar
Stingxray Stingxray is offline
My Photos: (0)
Default Update
Good morning Gent's :
I have some up dated photos of the Six link bearing housing bracket (No longer a trailing arm). They turned out better than expected. My welder called them "Suspension Jewelry" Thanks again Pier Paolo .......
  #134
Old 02-25-2011, 11:30 PM
Stroker-427 Stroker-427 is offline
Italy | Addict
My Photos: (39)
Default
You are welcome Sting!
Nice welding however..... TIG ?
  #135
Old 02-26-2011, 04:48 AM
Stingxray's Avatar
My Photos: (0)
Default
Yes Pier : Friends at work tig welded them up. They are Nuclear certified welders.
Question :
The Different CAD photos show .....the Toe brackets welded from the bottom or flipped and welded on top . Witch is correct ?
  #136
Old 02-26-2011, 08:00 AM
Twin_Turbo's Avatar
Netherlands | Der Maulwurf
My Photos: (1296)
Default
the top is correct, the bottom is my assembly as I was trying to figure out if all the individual parts were there.
__________________
  #137
Old 02-26-2011, 02:53 PM
BBShark's Avatar
BBShark BBShark is online now
United States | Garage Monkey
My Photos: (318)
Default
Nice job. Looks great.
  #138
Old 02-26-2011, 07:29 PM
1Michel 1Michel is offline
Canada | Addict
My Photos: (494)
Default
Man this is nice.
__________________
Eat dessert first! life's unexpected!
  #139
Old 02-26-2011, 08:44 PM
Stingxray's Avatar
My Photos: (0)
Default
Quote:
Thanks TT ...Wheew...... I'm sure glad we welded mine in correctly......
  #140
Old 02-27-2011, 10:49 PM
CrossedFlags77 CrossedFlags77 is offline
My Photos: (2)
Default
Stingxray, how much did it cost with material to get all of the pieces cut?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
