Go Back   VetteMOD.com > VetteMOD Workshop > Fabrication Section
Reply
Thread Tools
  #1
Old 01-31-2009, 10:14 PM
Twin_Turbo's Avatar
Netherlands | Der Maulwurf
My Photos: (1296)
Default V band clamps are the bomb
Had some issues with this magnaflow exhaust (under 69 Mustang 428CJ). Out of the box, it didn't fit quite right and the cheap band clamps don't seal well at all. Leaks everywhere, clearly visible by traces of soot (especially after cooling down and condensate forming in the exhaust, which subsequently leaks out) Even the damned X pipe was leaking where the factory weld overlapped (welded from 2 sides, overlapping/leaking blob in the middle)
I removed the clamped connections for the X pipe, welded the whole damn thing together so it will never leak again. The forward section was also fabbed, kit didn't even come with that section as a bolt on piece in stainless, just some crappy mild steel stuff. Welded in sensor bungs on both sides too, for some Wideband tuning
Even worse is, the clamps don't keep the mufflers from sagging/rotating. The hanger brackets are not placed properly on the mufflers (L&R muffler have the same hangers, both on the drivers side) so the hangers being off to the side makes that the muffler wants to rotate. Nothing worse than a crooked looking exhaust, especially since I fabbed some oval tips that fit the stock rear cutouts. If the whole shebang hangs crooked it looks like ass.
They are expensive but this is such a vast improvement over those other band clamps. They're junk as far as I'm concerned/
These things do take a fair amount of fiddling to get on straight. They're slightly oversize to slip over a 3" pipe but apparently the magnaflow pipes are not exactly 3", the V bands are significantly larger, making it tricky to weld them in place without the first weld pulling them crooked. I got it all welded on pretty neatly but it was a PITA.
I also welded the mufflers to the short sections with the V bands, no more leaks there either.
This wasn't even all of the modding I had to do, the rear pipes were too short, they ended under the car. I had to weld in a 15" long section to get the pipes to exit the rear. Also, the bend over the axle was all wrong on one side, I had to chop that side up, move the bends about and weld in sections so it would clear the axle, the shocks and not rattle against the frame. So much for a nice (expensive) bolt in kit. Would have been easier to build from scratch....cheaper too!
Here's some before pics, unacceptable or what? Tips hanging crooked...ugh!
__________________
  #2
Old 02-01-2009, 12:11 AM
mrvette's Avatar
mrvette mrvette is offline
My Photos: (3)
Default
Picky aren't you???
__________________
  #3
Old 02-01-2009, 02:50 AM
Stpman's Avatar
Stpman Stpman is offline
Canada | Addict
My Photos: (0)
Default
TT Where do you get these? They look like what I want for My 73
Steve
  #4
Old 02-01-2009, 04:18 AM
MYBAD79's Avatar
MYBAD79 MYBAD79 is offline
Germany | Crew Chief
My Photos: (882)
Default
I was going to buy some of these but I guess I'm too cheap....here's a link to another thread that contains the supplier info....
__________________
Link to my garage:
  #5
Old 02-01-2009, 08:58 AM
Twin_Turbo's Avatar
My Photos: (1296)
Default
got them off the bay of course 30$ for the clamps & 2 ferrules.
  #6
Old 02-01-2009, 09:04 AM
Twin_Turbo's Avatar
My Photos: (1296)
Default
Quote:
Originally Posted by mrvette View Post
Picky aren't you???
Those black traces are an instant MOT failure. They are picky here when it comes to that.
  #7
Old 02-01-2009, 01:00 PM
MYBAD79's Avatar
My Photos: (882)
Default
Which ones did you get ? Have a look at these, made by "OBX": item number 160305814016
These are the only ones that include a photo that shows the mating surface of the two flanges and the male/female fit. There are other flanges on Ebay that have just a flat mating surface.
Funny: one seller advertizes a "set of two" V-clamps for $24.95 and free shipping.... when you read closely you see that you're only getting the clamps, no flanges....
  #8
Old 02-01-2009, 08:32 PM
Twin_Turbo's Avatar
My Photos: (1296)
Default
I have a flat mating surface, no need for that step to center the 2 sides on each other, the V band clamp does that already. I would think that the step would make them a bitch to assemble if you have them just slightly off, the normal ones you can just slap teh clamp around and tighten down. These are 3" clamps.
  #9
Old 02-02-2009, 05:07 AM
kwplot34's Avatar
kwplot34 kwplot34 is offline
United States | Heart Attack
My Photos: (225)
Default
So do you suggest using these clamps or just welding the system up
__________________
I feel the need,the need for speed
Speed kill's. So ignore the speed/o :
Those satisfactions are permanent
Everything is going too fast and not fast enough
  #10
Old 02-02-2009, 02:14 PM
1Michel 1Michel is offline
Canada | Addict
My Photos: (494)
Default
I have some of those clamps on my truck, 5 inches. Everything is welded like you did. Trust me they get a beating and shaken up pretty bad. 200000kms this year and nothing leaks never even had to tight them up. Pretty good stuff. I would use them like you did because of installation once the system is built. you can tear down and put back together the exhaust in a couples of minutes.
Nice job, love that Mustang
Besides admit it, you love to weld so it wasnt that much of a PITA Huhh?. LOL
__________________
Eat dessert first! life's unexpected!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
