daveL82
- Joined
- Apr 10, 2008
- Messages
- 231
dynalite rear bracket question
I have the superlites on the front a really like them a lot. I'm now fitting the narrow dynalites to the rear and will be using a piece of 3/8 flat steel to make the adapter bracket as this seems to center the caliper over the rotor. The bracket will use the stock hub mount holes to locate it and I'll have to drill new holes in the bracket to mount the new calipers.
My questions is would there be enough material in the 3/8 steel to drill and tap for mounting the new calipers or should I drill through holes and tack nuts on the back (7/16x20 fine threads)? Tapping the holes gives me a bit more flexibility in locating the caliper.
