Go Back   VetteMOD.com > VetteMOD Technical Discussion > Paint, Body and Interior
Reply
Thread Tools
  #21
Old 11-01-2008, 06:57 PM
kwplot34's Avatar
kwplot34 kwplot34 is offline
United States | Heart Attack
My Photos: (225)
Default
Quote:
Originally Posted by Cherry View Post
For what I can see, you will have to use a builder primer in those areas where a lot of paint was taken off, You have a mountain to climb, If you have a painter friend, have him look it over before you start priming, that way you won't be going backwards on filling different areas to get it all flat, There are different grades of filler primer and dryers, I'm sure you know this? I'd say you have just scratched it so far,, Happy arms are to come. Hve fun.
I have some sealer and builder primer to put on there. Happy arms my arms are not so happy so i decided to take the day off from sanding take a little break,i have to spread all this fun out i don't want it to end to soon you know
Here is a question about the sealer.
should i apply it before putting on any putty to give it a base to bond too.
Or should i use the sealer after the putty is applied and sanded.
__________________
I feel the need,the need for speed
Speed kill's. So ignore the speed/o :
Those satisfactions are permanent
Everything is going too fast and not fast enough
  #22
Old 11-01-2008, 07:20 PM
MYBAD79's Avatar
MYBAD79 MYBAD79 is offline
Germany | Crew Chief
My Photos: (882)
Default
Shoot the epoxy primer/sealer over the SMC then use body filler and urethane high build primer.
Dunno how much you're willing to spend: PPG DP epoxy is awesome stuff but at $70/qt it's pricey - a gallon is probably around $220 or so..... I have used Kustomshop epoxy from TCP global and that seems to be pretty good too, half the price, $120 shipped.....
You can then spray sealer (reduced epoxy primer) between the high build primer and base coat - after you spray the sealer you only have a few days to shoot the base, otherwise you have to sand and spray another coat sealer.
__________________
Link to my garage:
  #23
Old 11-02-2008, 06:50 AM
kwplot34's Avatar
My Photos: (225)
Default
Thank you for the explanation some articles i have been reading were about as clear as the big Mo river.
I have PPG JP377 epoxy promer/sealer And PPG JP202 2K primer. Do those sound ok
  #24
Old 11-02-2008, 12:23 PM
MYBAD79's Avatar
My Photos: (882)
Default
Quote:
PPG JP202 is the "shopline" urethane high build primer - I used it on the '79 and on the Ghia. I like it better than the Kustomshop which seems to be thinner and does not build up as well. The shopline primer is easy to sand.
I have not used their JP375 epoxy but the JP385 which is a sealer that's designed to seal the primer before the base coat is applied.
Here's the shopline info-website (the search function is on bottom left).
  #25
Old 11-02-2008, 12:43 PM
kwplot34's Avatar
My Photos: (225)
Default
Thanks for the info Karsten
  #26
Old 11-03-2008, 12:51 AM
SMYDA's Avatar
SMYDA SMYDA is offline
United States | Knuckle Dragger
My Photos: (0)
Default
Quote:
Originally Posted by Dirtbuster1 View Post
Get a piece of plastic strap that they use when banding a box. Slide it under there with a back & fourth motion. It will take it right off. That is what they use at the body shops.
They DO!!!???
Good Tip.........I actually never thought of that but will definitely give it a try.
__________________
  #27
Old 11-03-2008, 01:01 AM
TimAT's Avatar
TimAT TimAT is offline
United States | Addict
Cruise-In Bird-Run 1 Veteran
My Photos: (60)
Default
Quote:
They DO!!!???
See there Coming around VetteMod can be a learning experience.
__________________
Why is it that all instruments searching for intelligent life are pointed away from the Earth?
  #28
Old 11-03-2008, 11:32 PM
kwplot34's Avatar
My Photos: (225)
Default
moving right along,i think this area is the part i hate the most so far,and what a friggn mess in the hinge area
  #29
Old 11-04-2008, 01:24 AM
MYBAD79's Avatar
My Photos: (882)
Default
Your camera takes photos of the future ???
looking good so far
  #30
Old 11-04-2008, 02:31 AM
kwplot34's Avatar
My Photos: (225)
Default
looking good so far
I know,you should see what happens when i take a pic of a Power ball ticket the day before the drawing
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
