Go Back   VetteMOD.com > Whats On Your Mind? > Off Topic
Reply
Thread Tools
  #1
Old 07-30-2008, 12:10 AM
big2bird's Avatar
big2bird big2bird is offline
United States | Charter Member
Founder Bird-Run
Cruise-In Bird-Run 1 Veteran
Cruise-In Bird-Run 2 Veteran
My Photos: (342)
Default For Easyasone2three
__________________
I can make your dizzy. Really, I can.
  #2
Old 07-30-2008, 04:19 PM
BRUTAL64's Avatar
BRUTAL64 BRUTAL64 is offline
United States Outlying Islands | Neanderthal
My Photos: (4)
Default
Ok, here's a test--What year is the Goat? Also what years are the T/A and Porsche?
__________________
"If it is left to the present Congress, we’ll get the best thinking of the eco-nazis, the safety nazis, the California Air Resources Board, Speaker of the House Nancy Pelosi, and the Biosphere 2 people. For the good of the nation and its citizens, these clowns should be kept as far from our automobiles as is politically possible."
David E. Davis Jr.
64 Vette Roadster 400 ci- Dual Quads
70 Thunderbird 429 ci
48 Harley Panhead 76 ci
  #3
Old 07-30-2008, 04:40 PM
Twin_Turbo's Avatar
Netherlands | Der Maulwurf
My Photos: (1295)
Default
If you past the img code you don't have to add the image tags, or past the code in the image wizard. Paste straight into the message area.
__________________
  #4
Old 07-30-2008, 05:23 PM
DJ Dep's Avatar
DJ Dep DJ Dep is offline
United States | refugee from the other place
My Photos: (5)
Default
The GTO is a 1965. The TA is a 1970 455 HO...or a clone of one. The front seats don't look right. It's also missing a Firebird decal at the front of the hood. Not the big one. A small one. Here's a pic of the "real deal".
  #5
Old 07-30-2008, 05:38 PM
DJ Dep's Avatar
My Photos: (5)
Default
Personally, if I were to get a T/A, I'd have to have this under the hood...
A true "Vette Killer" from the 70s
  #6
Old 07-30-2008, 05:54 PM
BRUTAL64's Avatar
My Photos: (4)
Default
Quote:
Well, you got the GTO correct. The T/A would be a 71-72 if it had a 455 HO. The 70 came with the 400 ci only. But still a good call.
  #7
Old 07-30-2008, 06:00 PM
DJ Dep's Avatar
My Photos: (5)
Default
Oops...you're right Glen!!! The 1970 had Ram Air III or IV engines. Best year I can guess is 1970-73. 1974 they reduced the size of the front spoiler.
  #8
Old 07-30-2008, 07:45 PM
mrvette's Avatar
mrvette mrvette is offline
My Photos: (3)
Default
OH man, olde Ponchos.....
my last Poncho was a '70 Lemans sport convertible I made a defacto GTO out of, and so 462 inches with #96 heads and RA3 exhaust t400 with Trans Go of course....12 bolt 323 posi and a 26 gallon fuel tank from a '79 caddy.....
the DPFI came from a '79 Sedan Deville 425 and got the car published in '95 Feb HPP magazine....Injected madness...it's a project I did myself in my garage over 92-93 winter in Maryland outside DC.....I upped the MPG from about 10 even to like 14+ on the highway....UNLESS I was towing my boat out to the Md/W.Va upper Potomac river, with me, 2-3 young teens, g/friend up front, me and the boat at 2900 lbs....I went into south mountain on I70 just past Fredrick Md, about a 10% grade for a 4 mile pull.....
I"d open that SOB up and the MOAN coming under that hood told of the `1000 CFM Tbody being WIDE OPEN and ZERO manifold vacuum....the duals roared and I would pull some 7500+ lbs of gear up that hill going in at 80 mph and topping out at the crest at 100 mph....I had the tires for it on both the car and boat, not THAT crazy.....when I saw the golden arches of the Appalachian Trail, I"d lift and be doing only 60-70 downhill.....
I had Global West suspension and large disc brakes, and tall '80 caddy spindles on it.....the sympathetic machinist mentioned in the article was not Bob Harris, who did just the short block to my specs...but a hippy type machine shop operator who did a lot of NASA satellite welding out of Goddard Space Flight just off US1 in Beltsville Md.....freeking guy has every tool known to man, and I shit you not....EVERY ONE.....
well, you know, except a Phillips screwdriver......
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
