Go Back   VetteMOD.com > VetteMOD Technical Discussion > Wheels, Tires and Brakes
Reply
Thread Tools
  #1
Old 07-17-2008, 05:16 PM
68L71's Avatar
68L71 68L71 is offline
United States | Addict
My Photos: (20)
Default Wilwood aluminum rotor hat
I have Wilwood front rotors but I am concerned with the thickness of the hat. I will be running aluminum wheels so the hat is thicker as well as the mounting surface of the wheel. I have stock length studs. The hat + wheel mounting flange = 7/8”, not including the conical seat. I have not measured how much stud protrudes. The Wilwood rotors are stock size, I was surprised how there seems to be little weight difference, maybe the difference is more than I think as I did not use a scale. Currently I am using stock rotors.
  #2
Old 07-17-2008, 05:23 PM
Twin_Turbo's Avatar
Netherlands | Der Maulwurf
My Photos: (1296)
Default
Install some longer 1/2" studs, the stock 7/16 are pretty weak. What hat & rotors do you have? Do you, or anyone else, know the hat offsets for front & rear?
__________________
  #3
Old 07-17-2008, 05:52 PM
BBShark's Avatar
BBShark BBShark is offline
United States | Garage Monkey
My Photos: (264)
Default
C3 Rotor Dimensions
__________________
  #4
Old 07-17-2008, 06:27 PM
68L71's Avatar
My Photos: (20)
Default
The rotors are the same ones this guy sells…. [Only registered and activated users can see links. Click Here To Register...]
I would like ½” studs, but is it really necessary on the street with street tires?
  #5
Old 07-17-2008, 06:51 PM
Twin_Turbo's Avatar
My Photos: (1296)
Default
Larry, is that front or rear? they are different in offset too.
  #6
Old 07-17-2008, 07:33 PM
BBShark's Avatar
My Photos: (264)
Default
Quote:
Good question. It's what I had here at work. I'll check when I get home.
I can't imagine that the Wilwood hats are thicker than the stockers. C3 roteors seem thicker there than any I have ever seen. 68L71, you should have at least 1.25 stud length (beyond the hub face).
  #7
Old 07-17-2008, 07:47 PM
68L71's Avatar
My Photos: (20)
Default
Stock = 1/4"
Wilwood = 1/2"
With steel wheels the wheel is thin but aluminum wheels have thicker mount flange. The only reason I am concerned is I would be using both thicker hats and wheels. If I upgraded to longer ½” studs it would solve the problem, but if I don’t need too, I do not want to go to the trouble of adding ½” studs. I need to measure how much stud protrudes but I need to pull the caliper to test fit.
  #8
Old 07-17-2008, 08:11 PM
BBShark's Avatar
My Photos: (264)
Default
Quote:
Originally Posted by 68L71 View Post
Stock = 1/4"
Wilwood = 1/2"
Stock should be at least 3/8". 1/2" hub face thickness for an alumunum hat is thick.
  #9
Old 07-17-2008, 08:57 PM
68L71's Avatar
My Photos: (20)
Default
Quote:
That was a factory rear rotor I measured.
  #10
Old 07-24-2008, 12:19 AM
redvetracr's Avatar
redvetracr redvetracr is offline
My Photos: (115)
Default
I`m using this one on the front...HD series fixed mount. please note, they measure offset kinda funny...you can (I think) get longer 7/16 studs, I don`t think I would use a 7/16 stud in a hat with a 1/2" hole...redvetracr
8 x 7.62" rotor circle
5 x 4.75" bolt pattern
1.50" offset
.51" stud hole
2.85" center hole
.50" face thickness
6.51"
.323"
Wilwood #170-0176
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
