Go Back   VetteMOD.com > VetteMOD Technical Discussion > Chassis, Steering and Suspension
Reply
Thread Tools
  #1
Old 01-20-2018, 03:46 PM
COLE SWEAT's Avatar
COLE SWEAT COLE SWEAT is offline
United States | Member
My Photos: (0)
Default Guldstrand rear toe adjusters
Has anyone made these adjusters for a c3 and how do they work?
Do they replace the pivot bolt?
  #2
Old 01-20-2018, 06:34 PM
BBShark's Avatar
BBShark BBShark is offline
United States | Garage Monkey
My Photos: (250)
Default
Saw a picture of one once. I think redvetracr posted it.
Pretty much a threaded sleeve on a threaded stud. You need to drill out and tap the pivot in the frame. Not sure on any of this
__________________
  #3
Old 01-20-2018, 06:54 PM
rtj's Avatar
rtj rtj is offline
United States | Addict
My Photos: (19)
Default
If you have chrome, and load the photobucket plug in, I’ve posted photos of home made ones.
Pretty much a copy of the photo mentioned above. But, no grease nipple as it would weaken the bolt.
I can’t log in to my photo bucket, but could probably find the pics later today or Sunday.
  #4
Old 01-21-2018, 01:03 AM
rtj's Avatar
rtj rtj is offline
My Photos: (19)
Default
Here are two photos. These pretty much show everything. There are more intermediate steps in the thread, the links can be used directly if you want ( copy link and delete [img] ).
Not to hard if you have a lathe.
The car was on jack stands, so my welding was even worse than on a bench.
You have to have the frame out or cut the fender for installation.
  #5
Old 01-24-2018, 06:12 AM
COLE SWEAT's Avatar
My Photos: (0)
Default
Thanks for the info. Is there a place to purchase these?
  #6
Old 01-24-2018, 11:30 AM
COLE SWEAT's Avatar
My Photos: (0)
Default
Were could I purchase these?
I am raising the pivot point 1 1/2”, so should I fill the stock holes?
  #7
Old 01-24-2018, 02:20 PM
rtj's Avatar
rtj rtj is offline
My Photos: (19)
Default
Just find a local machinist and take him 3/4 in grade 5 hardware. I have a frame that Im going to do differently, Two positions.
The link above has all the details on what I did.
  #8
Old 01-24-2018, 02:51 PM
COLE SWEAT's Avatar
My Photos: (0)
Default
what size is the pivot bolt?
I couldn't see the pics but what is the 1" drill bit for? are you making the hole in the frame 1"?
  #9
Old 01-24-2018, 06:27 PM
rtj's Avatar
rtj rtj is offline
My Photos: (19)
Default
Pivot bolt: stock dia.
Copy photo bucket links from my old thread and remove [img]. You have to quote to see the links Im talking about.
Once you see the photos, it will make sense.
  #10
Old 01-24-2018, 10:12 PM
BBShark's Avatar
My Photos: (250)
Default
I took your advice and loaded a photobucket fix. Works like a charm. Thanks
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
