rtj
- Joined
- Nov 5, 2011
- Messages
- 3,431
Kind of looking for some feedback.
$20K for a crate gm ZL1 (new production if they are still available). So I started looking at what it costs to buy the parts and the internet offered up this:
http://www.chevyhardcore.com/tech-stories/the-427ci-big-block-build-a-21st-century-zl1/
His new parts list is $12K.
If that is correct, this looks like a bargain:
BMP aluminum 9.8 block
Ohio Crankshaft 4340 x 4.250 crank
Ohio Crankshaft h6385 H-beam rods
SRP dome pistons 10.5 compression
Erson hydraulic roller cam
COMP Cams premium hyd roller lifters
BMP 345 cnc aluminum heads
Harland Sharp aluminum rocker arms
Canton oil pan
Melling hv oil pump
Prosport SFI dampener
Quickfuel fx1050 carb
MSD ignition
Ohio Crankshaft billet valve covers
$15k with dyno tune.
http://www.ohiocrank.com/enginespage1.html
Canton oil pan
Melling hv oil pump
MSD ignition
