Jeff, get a large metal tube, cut it along the length and remove a chink, cut it wider at the ends so the bushings can slide in. Smooth ends so it doesn't dig into the arm and use it to support the arm...then press away.
I always dress the holes in the arm w/ a little worn flapper disc to polish the metal smooth, a little grease and they go in like butter.
