Kid Vette
Master-Baiter
I'm in the process of swapping in an aluminum D44 to replace my iron Eaton diff. I did some measurements tonight.
I measured from the cover flange to the stub axles.
There is about 1/8" difference between the two. The D44 measures 2"; the Eaton measures 1 7/8".
I also measured the distance to the front pinion mount hole.
I held a level at the top of the hole on the Eaton and the drew a line at that level on the D44. The D44 is 1/2" lower.
So the distance from the pinion mount hole to the centerline of the stub axles is 5/8" less on the D44. So the pinion bracket on the frame should extend an additional 5/8" to locate the stub axles in the same position, right?
Beejay already ran into this when he did his swap. So I bought the section of frame off an 82 where the pinion bracket is welded on thinking I could just whittle it off and weld it on my frame - problem solved. But this is what has me stumped the bracket that I bought looks identical to the one on my frame now. So now I'm confused. Did they relocate the whole crossmember when they went to the D44?? :suicide:
