MotorHead
Member
Someone has finally discovered that our small block C3's are making way more power than the 200HP or so from the factory. So now anyone with a beefed up 350ci or big inch small block has an option in header size.
So I got a set of 1 7/8 inch primary into a 3 inch collector set today.
They are made from top quality 321 stainless steel and mandrel bent.
"321 stainless steel is most similar to 304 stainless steel, however it contains the addition of Titanium making it an excellent choice for prolonged high temperature applications. The addition of Titanium stabilizes this grade of stainless steel against the formation of Chromium Carbide in heat ranges between 800 to 1500 degrees Fahrenheit."
Got these today and I have to say they are without a doubt the nicest looking and best made headers I have ever laid my hands on, and I have seen many sets of headers.
I had one side on in 1/2 hour and they bolted up perfect to my existing exhaust which I didn't think would happen.
They are boxed up nice so as not to get damaged.
Couple of pics before I bolted them on. Notice how thick the flanges are.
They even ported the inside of the tubes at the flange, not something you see too often on other headers
